Clears protocol filtering counters.
| port_list | Specifies the port list is separated by a comma ( , ) or dash ( - ). |
| all | Specifies all ports |
Disabled.
Use this command to clear protocol filtering counters.
The following example clears all protocol filtering counters:
clear counters ports protocol filter
The following example clears protocol filtering counters on ports 1-5:
clear counters ports 1-5 protocol filter
This command was first available in ExtremeXOS 15.5.
